| Version(s): | 08.05.02.35 | ||
| Area: | UI Customization | ||
| Subarea: | General | ||
List of Miscellaneous tools. Looking for tool that used to be in
older version.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: UI Customization
Some older tools have been replaced with new versions of tools, some
tools were combined or a new tool replaced it.
However these tools are still available in MicroStation, but are only
available by adding them to a custom toolbox.
1. From Menubar, go to Workspace > Customize [Customize dialog opens]
2. Go to ToolBoxes tab.
3. In the Right pane, open the toolbox to copy the Miscellaneous tool(s)
or create a new toolbox.
4. In Left pane, scroll down to Miscellaneous tools (near the bottom).
5. Highlight the tool to copy over.
6. Press "Copy".
7. Repeat for all needed tools.
8. Close and save interface.
