| Version(s): | 08.05.01.25 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to dock pallets up next to the main menu bar so that space
can be utililized.
Product: MicroStation V8 2004 Edition
Version: 08.05.01.25
Area: Configuration
Set the variable MS_MAINMENUDOCKINGBESIDE. This is
a Binary variable and will need to be set to 1.
