| Version(s): | 08.05.01.25 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to disable the dialog "you have unsaved changes, would
you like to save it now?", when working in a V7 file.
Product: MicroStation V8 2004 Edition
Version: 08.05.01.25
Area: Configuration
Set the MS_V7AUTOSAVE_NODIALOG=1. If this configuration
variable is set, this dialog box is skipped and auto-save occurs
automatically.
