| Version(s): | 08.11.XX.XXX | ||
| Area: | Visualization | ||
| Subarea: | Distributed | ||
| Original Author: | Joshua Kulp, Bentley Technical Support Group | ||
Another potential problem is a machine not joining in the distributed rendering job. If this occurs and groups are being used, check the configuration settings to see if groups are seen.
Delete settings.xml for process controller
Browsing to and reselecting the shared directory may resolve the issue, if not, the settings.xml file that stores the shared directory and group information must be deleted. This will cause the scheduler to prompt for the shared directory information the next time the controller is started.
On a Windows XP machine the settings.xml should be in the following directory:
C:\Documents and Settings\All Users\Application Data\Bentley\DistributedProcessing
On a Windows Vista or 7 machine the settings.xml should be in the following directory:
C:\ProgramData\Bentley\DistributedProcessing
