| Version(s): | V8 and newer | ||
| Area: | Text | ||
| Subarea: | Find / Replace Text | ||
Bad version number-Problem using the Find/Replace Text command. When this command is selected (Edit > Find/Replace Text) he receives the following error:
"Bad version number for MDL application 'CHNGTXT'".
Version: V8 and newer
Product: MicroStation
Area: Text, Find/Replace
Rename or Delete the UPF (User Preference File) file, so a new one is created.
