| Version(s): | 08.00.00.00 | ||
| Area: | Text | ||
| Subarea: | Fields | ||
Can not edit datafields that are inside cells--When placing a cell that has a data field in it. When you go to populate the data
field you can not select it if inside the cell. If the cell is dropped then it can be modified. If cell is also placed in a new
file it works.
Product: MicroStation
Version: V8
Area: Text, Data Fields
Narrowed it down to be file specific. Suggested to fence the file out to a new file, or create a new file, reference in the original and then do a merge into master.
