| Version(s): | 07.01.04.10 | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
Cannot rename, delete or move a file, using Operating System (Windows
Explorer), if the active file is referencing it.
The error is:
Error renaming File or Folder
Cannot rename <(><<)>file name>: There has been a sharing Violation.
The source destination file may be in use.
Product: MicroStation J 7.1
Version: 07.01.04.10
Area: Reference,
This is expected behavior in MicroStation V7. This has since been
changed in V8, where the reference file is not tagged as being used
when a file is opened that has it referenced.
