| Version(s): | 08.05.02.35 | ||
| Area: | Levels | ||
| Subarea: | General | ||
How users can change hardcoded levels to a bylevel definition while
holding the scale factor of custom linestyles
Product: MicroStation V8 2004
Version: 08.05.02.35
Area: Levels
KB: Set the Custom Linestyle scale factor to the desired factor. Then
use the Match command, making sure the Use Active Setting toggle is
turned on.
