| Version(s): | V8 and V8i | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
What are the parameters for the keyin, "reference attach" or RF =?
Product: MicroStation
Version: V8 and V8i
Area: Reference
The syntax for this keyin is:
rf=C:\FolderName\FileName.dgn,ModelName,LogicalName,Description,SavedView,
ReferenceScale <CR>
You can omit some or all of the parameters except the first one (file path/name). For example:
nothing else is needed. Once the keyin is used the reference will be attached.
