| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Analysis | ||
| Date Logged & Current Version | Dec. 2015 10.00.00.10 |
The following message appears when trying to analyze a model in AutoPIPE, why?
Forrtl: severe (104): incorrect POSITION= specifier value connected
file, unit 101, file
Image PC Routine, Line Source
Libifcoremd.dll 0D7091AA Unknown
Stack trace terminated abnormally
To date there has only been two reported occurrence that caused the above to appear. Confirm the following to be correct:
1. Check Modal analysis
Make sure that there is more than 1 mode of vibration, suggest using "Analyze up to Cutoff Frequency" option (by default = 33 hz).
2. Confirm Time History analysis
If performing a fluid transient, do not enable "Ground motion" option. Instead display the Time History Analysis - Ground Motion dialog
3. Close program and delete the all folders starting that start with AP_ from the following location:
C:\Users\***username***\AppData\Local\Temp\AP_***
4. Confirm user has read / write privileges to the folder above.
Visual Fortran run-time error messages
