| Version(s): | 08.09.01.20 | ||
| Area: | General | ||
| Subarea: | N\A | ||
Example of how to run Level Command Keyins
Key-in String:
LEVEL SET FROZEN <ON|OFF|TOGGLE> [file:file-spec] <level-spec>.
Product: MicroStation V8 XM Edition
Version: 08.09.01.20
Area: General
Key-in String:
Example of using Keyin:
-File Name: Master.dgn
-Level Name: Electrical
Key-in string:
LEVEL SET FROZEN ON File:Master.dgn Electrical
