| Version(s): | 08.05.02.35 | ||
| Area: | Batch Processing | ||
| Subarea: | N\A | ||
How can I use the batch process from the command line with
spaces in folder path?
Trying to batch convert files that exist spaces in folder path;
when the path is read in DOS prompt, error "invalid argument"
is displayed, as it does not recognize spaces.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: Batch Processing
Quotation marks must be used and they most enclose the entire
argument.
For example if test.bcnv file exist in a folder with a space
(G:\Folder with space\)
Use the following syntax:
ustation -wabatchconvert "-iG:\Folder with space\test.bcnv"
