| Version(s): | 08.11.09.357 | ||
| Area: | GUI | ||
| Subarea: | General | ||
| Original Author: | Joshua Kulp, Bentley Technical Support Group | ||
new interface dgnlib seed file?
What is used to seed the DGNLIB file created when a new interface is
created at the File Open dialog?
Product: MicroStation V8i
Version: 08.11.09.357
Area: UI Customization, Problem ID#: 83697, GENERALINFORMATION
When you create a new interface from the File Open dialog, MicroStation
uses the seed2d.dgn file located in the "\Workspace\System\Seed
directory to create the new DGNLIB file. If the file or directory is
missing a new DGNLIB file will not be created.
