06. Importing Nozzle Loads from AutoPIPE into AutoPIPE Nozzle
Comments, Questions, and Answers about importing a model into AutoPIPE Nozzle:
Item #1: Importing Nozzle Loads from AutoPIPE into AutoPIPE Nozzle
Item #2: Imported axis orientation in AutoPIPE Nozzle is different than in AutoPIPE, why and can it be modified to match?
Item #3: There are 2 figures with different axes and the user is confused about what coordinate system is being used in AutoPIPE Nozzle
Item #4: imported file has a lot more load cases than in the original model
Table Of Contents - AutoPIPE Nozzle Wiki page
