| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | Sept 2019 08.11.08.35 |
Original Model has 3 temperature/pressure, 4 earthquake, 4 wind and 1 user case
But when exported to AutoPIPE nozzle it is showing 8 temperature/pressure, 8 earthquake, 8 wind and 2 user case
Why?
Example of Analysis Sets in AutoPIPE:
When importing into AutoPIPE Nozzle, one can select which Analysis Set loads are imported. Example: selecting Analysis Set 4
See only the load cases and results from analysis set #4 would be imported.
By default, the Analysis Set Number option is set to All, thus including all of the load cases considered in every analysis set. This might be important, because the results can be different depending on what settings and considerations were applied. But it is up to the user to decide which results they are interested in AutoPIPE Nozzle.
How to export / Import data to AutoPIPE Nozzle's Load tab using MS Excel
Importing Nozzle Loads from AutoPIPE into AutoPIPE Nozzle
