| Version(s): | 08.01.02.10 | ||
| Area: | Raster | ||
| Subarea: | N\A | ||
After attaching raster images via I/RAS B, Raster Manager display them
incorrectly in Bentle y Redline.
A workaround is available in v8.5 Redline by doing the following from the Raster Manager dialog box:
1. Choose Settings - Attachments (under File Information tab and Filename, verify the path to file is correct)
2. Under Location tab - set Geo Priority to Raster Header
3. Under Display/Print tab, check Apply Rotation & Affinity to Raster toggle ON.
4. Update view and raster image should display in the same manner I/RAS B displays image as well.
