| Version(s): | 08.01.00.00 | ||
| Area: | DGN | ||
| Subarea: | Save | ||
Save to V7 and working units change
V8 Working units are Survey Feet/Survey Feet. Save to V7 and Working
Units change to Meters/Meters
Product: MicroStation
Version: V8
Area: Save as V7
V8 Advanced section Resolution was set to 1000 per Meter. Change Resolution unit to match working units and V7 file will have the correct Master/Sub units.
