| Version(s): | 08.09.01.20 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to disable all customizations that are loading from a USTN.M01 file
without having to remove the path.
Product: MicroStation V8 XM Edition
Version: 08.09.01.20
Area: Workspace
Set the following Capability Variable:
CAPABILITY_UI_IGNOREMENUSFROMRSCMODFILE
* Ignore menus from rsc mod (.m01) files - the default is to show the
menus
