| Version(s): | 08.09.01.20 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to disable Customizations from loading that are specified by
MS_DGNLIBLIST or MS_GUIDGNLIBLIST
Product: MicroStation V8 XM Edition
Version: 08.09.01.20
Area: Workspace
Set the Capability Variable:
CAPABILITY_UI_IGNOREMENUSFROMDGNLIBS
* Ignore menus from DGNLIB files - the default is to show
the menus
