| Version(s): | 07.01.04.17 | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
REF2RCD: Fails to detach reference files which have been toggled off
within the active *.dgn
Product: MicroStation J
Version: 07.01.04.17
Area: General, Problem ID#: 4111, PROBLEMSOLVING
130168 solved within 07.01.04.02 of ref2rcd
