| Version(s): | 07.01.00.00 | ||
| Area: | Hardware / Input Devices | ||
| Subarea: | N\A | ||
User Drags the cursor across the screen it makes like a little a trail
on the screen.
Go to the Windows Operating Systems Control Panel > Mouse > Pointer Unmark Enable Pointer Shadow or Pointer Options and check the Display Pointer Trail setting.
