Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.05.02.27 | ||
Environment: | N\A | ||
Area: | DWG | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
Working in dwg files and the line styles show up in Design Model but not
in Sheet Model.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.27
Area: Workspace, Problem ID#: 23907, PROBLEMSOLVING
Enable PSLTSCALE
The keyin: DWG PSLTSCALE 1
This will scale the linestyles using the sheet model units instead of the de
sign model units.
