| Version(s): | 05.00.00.00 | ||
| Area: | File Access | ||
| Subarea: | N\A | ||
Can't open V7 file in MicroStation SE
A file saved as a V7 file in V8 can't be opened in MicroStation SE. Trying to open this file in SE results in an exception.
Turn Enhanced Precision off in V8 Set MS_V7SAVEWITHOUTENHANCEDPRECISION = 1
Older versions of MicroStation (<(><<)>7.1) don't support enhanced precision.
Setting MS_V7SAVEWITHOUTENHANCEDPRECISION=1 in V8 will force MicroStation not to use enhanced precision for V7 files.
