| Version(s): | V8 XM, V8i, V8i (SELECTseries) | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
| Original Author: | Conor King, Bentley Technical Support Group | ||
How to place an attached/referenced Google Earth image behind elements/linework when attaching in a 2D file
When a Google Earth image is attached as a reference into a 2D file, it is appearing in front of or on top of the existing elements/linework in the Active 2D file. How can this be set so the attached image is sent to the back or put behind the active elements/linework in the 2D file?
To get the elements to display in front of the pictures, we need to tell MicroStation to process that data last (or, in other simpler terms, process the reference data first). To do this;
