| Version(s): | 08.05.02.35 | ||
| Area: | OLE | ||
| Subarea: | N\A | ||
Variable no longer needed in MicroStation V8
MS_OLECNTR_CONFIG_USEINTERCHARACTERSPACING
The Variable "MS_OLECNTR_CONFIG_USEINT ERCHARACTERSPACING " is no longer needed when using MicroStation V8 & Above.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: DDE/OLE
This variable was designed for MicroStation V7. This became a non-issue MicroStation V8 unless the variable MS_OLECNTR_CONFIG_ALLOWEMF, is set. By setting this variable it may cause the characters to be pressed together.
