| Version(s): | 08.09.02.28 | ||
| Area: | Tools | ||
| Subarea: | N\A | ||
What happened to the Drafting toolbar in MicroStation XM?
Product: MicroStation V8 XM Edition
Version: 08.09.02.28
Area: Dimension/Measure
It has been renamed to Detailing Symbols. It is in the same location as
MicroStation V8, but the tools it contains are slightly different.
The following tools are no longer on the toolbar.
Place Callout Leader
Place Leader and Text
Place Callout Bubble
Define Properties
