Scenarios #1: Approved on the condition that SSL encryption is turned on directly in Bentley's licen
Answer:
CONNECTION Client must be installed to access SES-based products because it includes the licensing components. However, it need not be signed in if using checked out licenses. The following standalone workflow can be used instead:
