| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Modeling | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
Why is it not possible to use elbows with HDPE pipe as with steel pipe?
(Note from AutoPIPE Help: "For HDPE pipes, only Close and Wide are accepted options.")
At this time, AutoPIPE has only provided HDPE for B31.1 and ASME NC/ND and that uses the CC-N755-1 provisions. CC-N755-1 only permits miter bends for HDPE and provides B1 & B2 indices for miter and close bends only.
Otherwise, you would need to have stress indices for your HDPE bends that could be manually entered.
