| Version(s): | 08.05.02.27 | ||
| Area: | Configuration | ||
| Subarea: | General | ||
Wants to be able to double click on a drawing in Windows Explorer and have it open in an existing session of MicroStation.
Add one of the following to the MicroStation command line for the file association:
-SingleInstance=Prompt
-SingleInstance=Yes
-SingleInstance=No
-SingleInstance=Cancel
Place it prior to the "%1" Under normal windows operations this will cause an open session of MicroStation to close it's open file and display a DGN file activated "doubled clicked" from Windows Explorer.
EXAMPLE:
D:\Bentley\08050227\Program\MicroStation\ustation.exe -SingleInstance=Yes "%1"
Further Command Line Options
File Associations
