| Version(s): | N\A | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
Unable to create a new file /..../name.*.
The variable value of MS_DESIGNFILTER had been set to use *.
MS_DESIGNFILTER=*.*.
Because .* is an invalid Windows extension value it will not create the file
MS_DESIGNFILTER should be set to a valid extension such as DGN
