| Version(s): | 07.01.05.03 | ||
| Environment: | Windows XP 32 bit,Windows 7 32 bit | ||
| Area: | Cells | ||
| Subarea: | General | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
Cells do not appear in cell library. When cell library is loaded no
cells appear.
Product: MicroStation V7/J
Version: 07.01.05.03
Area: Reference, Problem ID#: 69458, PROBLEMSOLVING
Cell in library need to be re-indexed. To do this compress the cell
library.
1. Go to cell library dialog
2. Go to File>Compress pull-down menu
Cell should reappear
