| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Modeling | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
How to add Seismic load case "Seis Ind Cmb.1-HDPE{1}" for HDPE combinations for ASME 31.1 piping code?
Specifically, after analyzing the system, select Tools> Combinations, Code combination tab, press the "Seismic Combs" button, specify both a "Equivalent Seismic Wave Prop Case" (T1) and "Seismic Anchor Movement Case" (S1) for each Comb 1-4, note "Soil Settlement Cases" are optional. Press OK button to close the dialog screen and press "Reset Default Only" button, now "Seis Ind Cmb.1-HDPE{1}" combination will appear in the "Combination" column.
See online help and Documents folder in the AutoPIPE directory for "Tutorial-ASME_B311_With_HDPE.pdf" for more information
