| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Jan 2015 09.06.01.10 | ||
Is it possible to calculate HDPE pipe using any other (non-nuclear) code than N-755-1?
Yes it would be possible, define Non Standard (NS) Pipe, enter the correct values of allowable, modulus and other data required for calculations
