| Version(s): | All V8 | ||
| Area: | DWG | ||
| Subarea: | Open | ||
When opening autocad files that come from clients, the elements appear
to be locked.
Product: MicroStation V8i
Version: 08.11.04.443
Area: DWG
Edit pull-down > Select All
Edit pull-down > Unlock
