| Version(s): | 08.09.02.12 | ||
| Area: | Configuration | ||
| Subarea: | General | ||
How to stop all hints from displaying in MicroStation V8 XM Edition.
First turn off the Position Mapping Preference 'Show Position Mapping Aids'. Next set the configuration variable: MS_NO_POSITION_MAPPING_HINTS= 1
Note: all hints, including those associated with the Main and Active Tasks will not be displayed.
