| Version(s): | N\A | ||
| Area: | Dimensions | ||
| Subarea: | Display | ||
| Original Author: | Jutta Eisenhauer, Bentley Technical Support Group | ||
New dimensions are missing
Dimensions are stored in an undesired level which is not displayed
Change level in the Dimension Styles settings
Open "Dimension Styles" toolbox > Advanced > General > Placement > Level
If a level without brackets is set this level is fixed for new dimensions.
Only if a level with brackets e.g. (Default) is set the dimensions will be placed on the active level.
