| Version(s): | 08.05.02.35 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
Locking configuration variables all at once.
Aside from using the %lock command on each variable ... is there a way
lock all variables at once (or an easier way)? Maybe with a %if command
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: Workspace, Problem ID#: 7805, GENERALINFORMATION
Currently there is no way to completely lock all variables at once. Would recommend to make the configuration files read only and
to also prevent users from making modifications remove "Configuration' from the workspace pull down and remove the configvars.ma
to prevent user from make changes through MicroStation itself.
