| Version(s): | 08.05.00.64 | ||
| Area: | Animation | ||
| Subarea: | General | ||
Receiving Error: 9 Saving Sequence when recording animation script.
Product: MicroStation V8 2004 Edition
Version: 08.05.00.64
Area: Visualization
This means the output can not be saved.
Possible Reasons:
1. The output destination does not exist.
Solution: check the path or rebrowse to the location.
2. The output destination is read-only or lack permissions.
Solution: Get permissions (from site administrator) to write to destination folder.
3. When setting the name of the output file, the correct about of "place holder" zeros was not used.
Solution: Rename the output file name to include the correct about of
place holder zeros.
Example: For a 300 frame animation the file name should be "framename000.jpg" (or the extension associated with the desired format).
