| Version(s): | 07.01.04.16 | ||
| Area: | Import/Export | ||
| Subarea: | N\A | ||
Microstation J supporting AutoCAD 2004/2005 files--Are there any plans to upgrade the DWG translator in MicroStation J (7.1) so that it will translate AutoCAD's latest 20004/2005 DWG files?
At this time no more development work is being done for Microstation J. There are no plans for updating Microstation J's DWG Translator
