| Version(s): | 08.11.07.171 | ||
| Area: | Programming | ||
| Subarea: | N\A | ||
| Original Author: | Marco Salino, Bentley Technical Support Group | ||
How to Change Fill Type using a key-in so that it can be used in a batch process
This may initially not seem possible as the key-ins "create region
flood" and "change fill" both require to manually select the fill type
via the interface.
The Calculat pre-processor is required in order to change fill type through
a key-in
The following key-in loads the pre-processor and change the fill type:
mdl load calculat; calc tcb->ext_locks.fillMode=1
Where "1" is for "Opaque", "0" is for "None" and "2" is for "Outlined" fill types.
If Calculat is loaded separately, using the "mdl load calculat" key-in,
or at start-up, then the following key-in is required for changing the
active fill type (to opaque in this example):
