| Version(s): | 08.11.07.443 | ||
| Environment: | Windows 7 64-bit | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
Creating saved view from polygon(shape).
Product: MicroStation V8i
Version: 08.11.07.443
Area: View
1. Choose the Clip Volume tool (e.g. from the view border).
2. Choose Two Points or Polygon as method
3. Define the Clip Volume (in view plane) and select view.
4. Save the clip volume by creating named fence from clip volume
5. In Create Save View dialog go to the Clip Volume method and select the saved clip volume.
6. Click left mouse button to accept the clip volume and create new saved view
http://communities.bentley.com/other/old_site_member_blogs/peer_blogs/f/275724/t/89208.aspx
