Technical Bulletin MicroStation V8 XM Edition And SignCAD
If you are using SignCAD XM Edition on MicroStation V8 XM Edition and are finding Edit > Paste inaccessible through SignCAD, we recommend that you log a Service Ticket against MicroStation V8 XM Edition (referencing Trouble Report (TR) #247357) and you will be contacted about a resolution to the issue.
