| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Modify | ||
| Date Logged & Current Version | Mar. 2015 09.06.01.10 |
What changes where added in the Rotate command in version 09.05 and higher?
Until version 9.5.1, only piping and frame points are rotated. Some enhancements were added but a major update to the rotate command was added in AutoPIPE V8i 09.06.00.xx and higher. Here is the list of new features which has been added in v9.6.0:
New rotation option
- Rotate about global coordinates
Geometry
- Valve actuator
- Additional Weight
- Supports (Incline, rotation and damper)
Loads
- Concentrated forces
- Imposed Support Displacement
- Thermal and Seismic anchor movement
- Distributed Loads
- Wind
- Static Earthquake
