Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.11.07.443 | ||
Environment: | N/A | ||
Area: | GUI | ||
Subarea: | Docking / Resizing | ||
Original Author: | Derval Canny, Bentley Technical Support Group | ||
Ability to permanently dock tool settings to the task menu on the left hand side of screen.
Workspace>Configuration>
MS_MAINMENUDOCKINGBESIDE
Set this equal to 1.
Save Settings.
You should now be able to dock your
toolbars.
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/dock-stuff-to-the-left-of-file-in-the-menu-bar.aspx
