| Version(s): | 08.11.09.459 | ||
| Area: | Configuration | ||
| Subarea: | N/A | ||
| Original Author: | Conor King, Bentley Technical Support Group | ||
When using the Attach Reference tool, it takes a long time for the Attach Reference Dialog to appear (up to 1 minute)
Workspace is stored on the company server and server has been changed/upgraded recently, since the change the Attach Reference tool performs slowly. It is possible the old server path is still being used and MicorStation is spending time looking for this path when it is not valid
