| | Applies To | | |
| | Product(s): | MicroStation | |
| | Version(s): | 08.09.04.88 | |
| | Environment: | N/A | |
| | Area: | Security | |
| | Subarea: | Digital Rights | |
| | Original Author: | RenZhi Hong, Bentley Technical Support Group | |
Keyin to encrypt dgn files
This Keyin works on MicroStation 2004, MicroStation XM and MicroStation V8i version.
- From MicroStation main menu Workspace>Configuration, choose ‘Protection’ from the Category list on
the left. - Choose ‘Enable file protection’ from the list on the right, click ‘Edit’ button and input ‘2’ as a
new value. Press OK and exit. - Keyin: ‘Protect Encrypt Password xxxxxx’ (the password xxxxxx should include numbers and letters, the
minimum length is 5 by default.) - If protection is no longer required, with the file opened, Keyin: ‘Protect Encrypt Remove’ this
will remove the encryption.
