General | ||
| Disabled | Enabled | |
Show flow Arrows | ||
Line Number | ||
Settings |
See AutoPIPE help for details | |
Use Selected Range | ||
Automatic Split | ||
Ignore Break Points | ||
Data Tables | ||
All data on separate sheet (Separate) | ||
Context data with drawing (Context) | ||
Pipe | ||
Identifier | ||
Diameter | ||
Diameter Change | ||
Schedule | ||
Tag | ||
Flange and Valve | ||
Flange Rating | ||
Valve Rating | ||
Flange Tag | ||
Valve Tag | ||
Points | ||
Point Name | ||
Tee Name | ||
Annotation | ||
Pipe Tag | ||
Bend Information | ||
Supports | ||
Support location | ||
Support ID | ||
Support Tag | ||
Support Attachment Id | ||
Anchor Tag | ||
