| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | June 2019 12.01.00.10 |
When importing an AutoPIPE NTL file from the PCF translator the following appears:
Confirm
Import process successful. Review warning messages :
Yes No Cancel
What should I do?
Select one of the buttons as needed:
Yes - will open both the *.MSG and *.CHK files in AutoPIPE Report Viewer for user to review each item of interest to the user. Suggest to always use this option
No - the report viewer will not be displayed and the file will continue the import process into AutoPIPE
Cancel - the command will be canceled
PCF Translator FAQ & troubleshooting
