02. Results Post Processing in AutoPIPE
Specific Topics:
  1. "Time History" Results
  2. Animate Load case
    1. FAQ's about Animated Load cases
    2. Review the results about a Run node point or Tee node point
    3. Pipe support moves with pipe during Animation, why?
General questions:
  1. Hand calculations do not match AutoPIPE Calculations. What should we do?
  2. Equipment load output: global or local coordinate?
  3. Different results between 2 identical models in the same version of AutoPIPE OR different results with the 1 model between 2 versions of AutoPIPE
  4. Summation of forces and moments about a Tee
  5. After generating an Output report the active window is AutoPIPE's program window and not the Report Viewer window
  6. Combinations involving User 1-140 are not correctly added in combinations
  7. Review the results about a Run node point or Tee node point
  8. What is more important, Operating Conditions or individual load cases?
  9. Check stresses for different pipe sizes separately
  10.
Post Processing - AutoPIPE
