| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Combination |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
How to Disable all Non-code combinations in the analysis and reports?
Perform the following steps:
1. Under Tools> Combinations> Combination options> put a check in front of "Disable Auto Non-Code Combinations"
2. Ensure that the Non-Code Comb tab is selected, press Delete All, this will delete all non-code combinations.
3. Press OK to close the dialog and then analyze the model
4. Review the Non code comb tab, there should be no combinations at this time.
This will ensure that no non-code combinations are printed.
Otherwise, on the Tools> Combination> Code or Non-Code comb tab disable / uncheck the entire Print Column, shown below
